MXT transmission oil?????
TYSHO
Earth
You need to search differential pins on this forum before you go drive hard, because whatever fluid you choose will be on the road...
I use Valvoline Mercon & Ford Mercon.
ckinney89sho
fo SHO
NY
i just put in royal purple about 90miles ago and it seems to shift better, but still notchy. it was $60 for 3 Qts.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
if your syncros are losing their linings, Valvoline max life ATX is good... other than that... I've noticed with a synthetic, the gears fall in place a lot easier. I prefer Mobil 1, but I also think that it breaks down faster than the rest.
Phoenix
SHOHOLIC
QC , Canada
Whoa I would be confused more then anything with all these answers.
You can use any good ATF (automatic trans fluid) , if you get synthetic , its better. But ATF is what goes in there.
Some used GM synchromesh and loved it as well.
