I’d rather have @Ryan Selcer uncensored than this @Matthew Kassing fellow. Cmon Ryan ...the Jig is up
enjoy my first post.
You aren’t the first person to put them on so I don’t know what being a thorn in someone side is all about. This isn’t that serious....and the comment about no wonder I don’t see 1000hp SHO’s or something to that regard....clueless on how that correlates to expensive brackets to look good? To each their own. I’m sure they will look great on your SHO.I just want to be that thorn in your side when I put them on and everyone cries
Practicing my moves for when I need to show up and teach someone a lesson!@Ecoboost_xsport , @Nova and anyone else....I believe it is time to start the band back up.....
To many variables is exactly why I haven't bought a set honestly. I love how they look on @FiveLeeter918 car.
I'll admit that I rushed into this too much and I didn't get adequate before testing, so it wasn't a true apples to apples comparison.
My 60-0 with the Wilwoods and R1 rotors and 245 General GMax RS tires was 2.57 seconds, 114.71 ft with a -0.86% slope, Jordan's was 2.62 seconds, 116.65 ft with the Powerstop kit and a +0.28% upward ascent.
Before the wildwoods with bone stock brakes, my best was 2.75 seconds, 124.33ft with an upward ascent of 1.06%. With the R1 setup as a baseline it dropped to 2.68s, 113.11 ft with a 2.66% grade.
Jordan's car full weight weighs 400+ lbs less than mine, the downhill grade for me didn't help especially considering the added weight, but how much difference would it have made?
400lbs less and stopped faster, on a slope down even? That should pretty much sum up everything we need to know to be honest.
0-60-0. 5 times, back to back.You missed the whole point of my post bro. No matter what you post on here, it will ALWAYS NEVER just be about you and your car. Every major post takes the scenic route. Also Jordon is correct. With the tests that were posted via Dragy the juice isn't worth the squeeze.
Also I hope you buy whatever you buy. I will extend a real world challenge to you so the community can see actual results. We can compare my set up vs whatever set up you buy. We can use my Dragy and we can test whatever speed to zero that people want. Same street, same conditions, same time.
Me as well.I would absolutely want to see this conducted. Same ambient outside temps, streets, elevation, same tires. The tests conducted before had to many variables to be considered a fair comparison.
Glad I’m not the only one that considers this aspect of the brakes.Me as well.
0-60-0 done 5 times in quick succession.
My money is on the aluminum calipers, edging out by break 3.
But that was 1 run. Do it a few times. Stock iron calipers will be boiling in no time. Aluminum stay cool longer, and cool off faster.
