SHOracer14
Me-0 Diffs-6
Ok, the auction block special was bought with a non working tranny.... there were some other issues I didnt look into because I just wanted to get it running. Now that I have completed the tranny swap these are some issues I am having...
First, the car must have had some sort of remote car starter on it that was one of the crappiest wire jobs I have ever seen so I am trying to go through and yank everything out and rewire to stock. Two problems I believe this is causing is the tach is inoperable (I'mthinking a wire off the coil pack) and also only half of the dash lights are working. The left hand side (tach and half of the speedo) works but the other side does not. Is it run on one power source or maybe just burnt out bulb(s)? Also the lights on the shifter are not working.
Second, the car does shift into overdrive but the overdrive button on the shifter is inoperable for an instance when I would want to disable overdrive.
Third, there were absolutely no problems with the heating system before the tranny replacement but now it seems as if the heater core has gone bad (steam with coolant smell even with EATC turned off). Coincidence?
I am also seeing the check engine light flash on every once in awhile but I haven't had a chance to check the codes yet. also I noticed that every so often when coming to a hard stop the car will die. Seems a lot like a VSS but the VSS is brand new. Bad part?
