Mtx Vss?
Axianator
I am a banana!
Roanoke, TX
While working on the V6 MTX strategies, I have found the VSS to be used in the following areas:
- A/C clutch cycling and system operation
- decel fuel shut-off logic (e.g. speed limiter)
- low- and high-speed cooling fan operation
- vehicle speed control logic (e.g. cruise control)
- idle speed control logic (during vehicle coastdown)
Axianator
I am a banana!
Roanoke, TX
Per the factory strategy documentation, the VSS is utilized in the following areas on the V6 MTX:
Axianator
I am a banana!
Roanoke, TX
Per the factory strategy documentation, the VSS on the V6 MTX is utilized in the following areas:
Ace
Manning Hater!!
Norfolk Mass.
it must do something because mine spits out a code and leaks fulid right where it connects to the cable...i need one kinda quick..
