bkmonster
Hi,
I have a 93 SHO with a MTX and I recently changed the transmission fluid when I replaced one of the axle seals. I only had access to the dexron mercon type atf. In a couple of weeks I'm going to be taking a ~5000 mile cross country road trip, and I was wondering if this would be fine, or should I change this fluid to one of the synthetics or the f-type transmission fluid. If I should change it, what is the recommended fluid?
(my car has ~117,000 miles on it, and I had the transmission replaced the transmission at 92,000 miles) Thanks for the help!
Jake
Jake
