MTX svc
smccprez
ca
Hello, I want to svc the tranny on my 91. Has 175k.... What does it like?
Thank you
JATO
Norman, OK
I've used both Dex3/Mercon and Mercon 5 in my MTX and I prefer the Merc 5. It seems to shift smoother and I have about 190k on my transmission.
itwonder
VA
I've tried a few, and ended up back where I started: Mobil 1 ATF
smccprez
ca
Seems like I have a few options..... Thanks for the input. I haven't been under the car except to change the oil so i never looked for a tranny drain plug but I'm assuming its fairly accessible? Also, how much fluid to use?
Devin
3.Slow
Pacific Northwest
Yeah, unless someone took the time to install one, there is no drain plug. There is a fill plug on the left side (read: pointing towards the front bumper) that can be used to pump the fluid out (what I did), or you can do a search on the forum for instructions on adding your own drain plug.
smccprez
ca
Lol no drain plug? Im used to auto muscle cars & haven't serviced a manual tranny. I put pans w/ drain plugs on my autos..... Procedure please?
JDUKE89
Florida
Ok GUYS I HAVE A PROBLEM I AM HAVEING SOME NOISE FROM MY GEAR BOX HOW WOULD I TELL IF MY DIFFERENTIAL IS GOING BAD 1989 SHO
chrism3784
West Palm Beach, Florida
when you drive you'll hear clucking noise and the tires sometimes locking up. That means the pin popped out and you need a new diff. Seeing how hard these transmissions are to come by, may not easily find one again. I been through 3, till I finally smarted up and got the one in there now welded. I recently had to get the reverse fixed. These tranny's suck.
