I'm having a problem with my 92 MTX SHO. It has been running with no problems for some time, but a couple days ago it wouldn't start. It seemed like the clutch wasn't enaging (about 10k miles on it). Sure enough, the clutch pedal position sensor had come loose. I reconnected it and voila, no problems starting. One day later, I start the car again without problem, but today I tried to start it, but it had the exact same problem. I checked the clutch position sensor, but it was connected this time. I even disconnected the sensor, cut the wires and connected them manually to bypass the sensor, assuming it was faulty, with no luck. I am stumped, does anyone have any ideas what it might be or what I could do? I checked the obvious (fuses (all good), battery (brand new)) and all the gauges come on but the engine doesn't even begin to crank. Suggestions would be great!
