mtx no 3-4
91PDXmocha
Portland , Oregon
I had a 91 mtx that would not go into 3rd or 4th. Tonight I took the case apart to see if I could locate what the damage was.
honestly everthing looks fine. some wear on on gears but nothing that looks bad at all. bad pics but does anyone have any ideas whats not working or is broken ?
what can i do do find out ? just keep taking it apart ...
thanks for any help.
I expect you will find something wrong with the 3/4 shift fork - broken or missing pin or fingers are most likely in my experience.
91PDXmocha
Portland , Oregon
this mornign after some sleep went out and took and new look at this thing. Pretty sure I found the problem.
again horrible pic but I think it serves its purpose.
This is my first rodeo on a SHO MTX but im guessing there is not sposta be this big chuck missing from this fork ? i cant see the chunk in the case anywhere .
is this commen ? what does this part run $ on avg ? how much do I need to remove to change it out. and yes i will def be cleaning this thing out and finding the chunk.
91PDXmocha
Portland , Oregon
followed Bizzys write up and got all the shafts and diff out. (man that shift pin did not want to come out at all ) looks like the fork is only thing damaged as far as I can tell . Cant find the chunk missing tho which is a little scary.
What cleaner is best for these internal trans parts ?
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
Evan,
We have a few boxes of misc used transmission parts, so we can get you the parts.
Honestly, transmission fluid is a pretty good cleaner on its own. Try using some new clean fluid if you need to clean any of the parts. They should not be that dirty, are they?
Mike
91PDXmocha
Portland , Oregon
No not really, they all look clean besides the nasty old metallic fluid left sitting around. Thanks guys . Ill give you a call later Mike.
