93rev2sev
History
I was hit while stopped at a light and the only mechanical damage was to my trans case - upon impact my motor must have jumped forward and snapped the shifter equalizer bar mounting ******. I drilled/tapped the hole a little deeper and put in a longer bolt, but it's starting to fail after about 2 years.
Present
I have a new transmission case but have no idea how easy or hard it will be to swap it out. Other than the cracked case the trans works great.
I have had the tranny out of the car before and can certainly get it out again. What will happen when I set the case on the bench and remove the broken shell half? Will parts spill out? Is it safe to pull the broken half off and put the new one on and bolt everything back up?
I'm worried that once I open the case, I will need a tranny mechanic to put it back together. As this is my daily driver, it would be bad if I take it apart and can't get it back together.
Present
