motormount question.
Freshusmc
Buford, GA
has anyone made solid mounts out of stock ones? how bad is the vibration if so and how to do it? or if the is a earlier post on this can you point me in the right direction?
shomtx95
wilkesboro,N.C.
i would use the search button as there is tons of info on here about this topic. All reinforced mounts (even the ones you buy) start as a stock mount. lots of people just drill holes through the mount and run 1/2 inch bolts through the mount. like i said before the best thing to do is search. i would imagine the vibration would be pretty harsh.
Freshusmc
Buford, GA
i have searched and cant really find what im looking for i guess ill just have to figure it out myself
AREA 91
PA SHO SHOP
Area 91
You do NOT want any solid mounts.
Reinforced engine mounts are the way to go.
Several member's on here make them (including myself).
You can post in the Wanted to buy section for mounts here on the forum.
Reinforced mounts can also be purchased through one of our great forum sponsers!!!
www.shonutperformance.com
www.shosource.com
:wave:
Brian
TYSHO
Earth
I am speaking on what will solid mounts break and where are the personal pictures from the experience?
raff18
frosty95mtx
ontario canada
i have solid ones the nvh isent that bad and i have alum bushings too its not all that bad u can realy feel the motor but if u dont like that kinda thing then go reinforced. i have talked to ALOT of people who have worked on cars for meny meny years they have all said as long as ur not drag striping the car or autox all the time then solid are fine just check ur bolts on the mounts every so often and tighten as needed so its up to u but the nvh does go up but u can live with it easly
raff18
frosty95mtx
ontario canada
engineers ummmm none but the shops i have talked too have worked on boat loads of cars with way more hp than my sho one even with 650 if i remember right and it was solid and never broke anything
