Motor Mounts
TicoSHO
93 in Largo, FL
Largo,FL,USA
How much should it cost to fix the motor mounts? I don't know if I need one or two.
Thanks.
SHO--ripper
928 Euro
winsted,CT
I think a shop would charge 3 hrs labor plus parts. It's a good idea to change both if your motor is moving around. Chances are that if you broke the front mount and kept driving the rear probably broke too.
Fourcats
Longview, WA
Mike{shopartsnw} :thumb: replaced the front{worn but not broken} mount of our '89, which made a noticable difference in driving. It was two hours, the new part and a gallon of green stuff...
F-22 Raptor SHO
7015 feet above Sea Level
how much to fix the front mount? Well a new extreme mount is like 150 bucks. Never have to replace it again. You can replace it yourself in about 2 hours, so I would say its 150 bucks to replace. Front mount is the one that is most likely bad. Replace that and see what happens. The rear is probably fine.
