motor mounts
fast4door
wichita
does anyone seem to have trouble with thare motor mounts i just replaced the tranny mound the the upper moutermound and the mone i didnt replace just went out. he heard these cars had weak motor mounts. is this true and if so is thare a stronger set i can get
DigDeez
Chicago
I'm planning on doing mine, the rear motor mount, within the next few days. I'm hoping I don't run into any problem, especially since I'm not too mechanically inclined.
DigDeez
Chicago
Elbow grease?! Well, how bout some petroleum jelly! :naughty:
Just kiddin' :evil_gri:
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
The front is easy.
Rear, not so easy. Can be a major PITA during reinstall if you dont drop the subframe a bit.
fast4door
wichita
well its not that bad yet. i can feel a slight tip in the motor. feels like the passanger side is lefting up when i give it a bit of gas and when i let off if it but if im at high speed like 60 and let off it if i cant feel anything. my qestion is will i be ok if i baby the **** out of it till next saturday or should i park in and drive my beater toyota for the time being...
marvsho17
Joshua S.
rockford, il
It'll be fine to drive it. BTW, I didn't have to drop the subframe to get my front and rear mm's in.
revhardSHO
Seattle, WA
You shouldnt need to worry about your transmission mount. Its basically just there to hold the trans in place and to keep it level with the motor. Its the front mount that takes most of the torque and abuse.
