Motor Mount Question...
DrCheeto
Lurking
Plainview,NY
Is it just me or does everybody list the wrong front motor mount for a 91?
Everywhere I've checked (Autozone, Advance, O'reilly, Rockauto) all have a hydraulic mount with a single bolt on top, nothing NEAR what either of my 91's have....
I pulled a good mount off of a 93, It looks the same as the one I have in there now....
Anybody know where I can buy the CORRECT mount?
Mr Anonymous
Tire Wall
MTX motor mounts have always been a Ford-only item, and last I heard they were discontinued. The only MTX mount I'm aware that was ever available aftermarket was the tranny mount.
As Marcel said, give Josh at http://www.shonutperformance.com a try for some reinforced mounts.
DrCheeto
Lurking
Plainview,NY
Ok, I thought i was insane.. I ordered a mount from autozone, and it showed up, and it was a regular Taurus mount.. Everbody's computer shows that the mount fits the 3.0, 3.8 and SHO (lol)...
It's ok, I found a good mount at the pick and pull for 3 dollars today, I'll use that until I can afford a reinforced mount. (I assume all year MTX mounts were the same?)
93rev2sev
Hockeytown
K-Dawg said:
Run some bolts through it to reinforce it yourself.
Yes, they are all the same.
I'm with him!
a 351 Windsor rod bolt set is enough hardware to reinforce all your mounts. Tighten the bolts just enough to start compressing the rubber. Use loc-tite or double nut them. Or use longer bolts and rear stabilizer link bushings to make a "softer" reinforced mount.
DrCheeto
Lurking
Plainview,NY
I just bought some bolts, and some window weld (polyeurathane), and made what appears to be an indestructable mount :naughty:
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Window weld? Not nearly strong enough.
I use this stuff :naughty:
NJSHO
Clean Your Shorts!
NJ
93rev2sev said:
I'm with him!
Done and Done.
Best mod ever. Plus its adjustable. Goto the track and just crank em down. A couple of grade 8 bolts from home depot will also work.
