SHOspazz92
Banned
Just curious.
-Sam
-Sam
An intercooler should allow better timing. Timing will get you the extra power. I thought he's posted numbers of his 9PSI setup.them's the numbers off his 8psi setup. Run an aftercooler, back off the timing and tune the shit out of it, I can easily see 425+whp....
Well, the 48lb injectors and 80mm MAF are maxed out @ 380hp, so right around that number I think. I seem to remember seeing a 369whp FPS SHO once.
With 44lbs/hr injectors and an 80MMLMAF I got that at the wheels and still had a decent amount of room to go. I currently have 48lbs/hr and the same MAF and I'm faster than I was before (bigger motor, more boost).I got 48lbs and 80 MAF.....meez got over 380hp. :type:
I think at this altitude, I was only hitting 60 - 70% DC. In AZ and didn't max them out either.static isn't such a bad thing is it?!? hahahaha
I gets lotsa fuel that way!
VRRRROOMMM!!
Tim, is Doug using a different charger than SHO Shop's, or something? I got 419 whp using a Ford 80mm / Accel 48 lb'ers. A 408 hp graph is in the dyno section now under (over, actually) my '91's.
Guess I should have put sarcasm markers on my post. I was simply quoting FPS when it comes to the power available from the stated components. Sorry, thought all would catch my attempt, since I made 430whp with an 80mm and 47's.
I got it![]()
I'm only seeing 82% duty cycle, but I'm currently running 65# injectors at a base fuel pressure of 48.5# .......
BTW, I never sounded out your screenname before. Cool! Sounds like a very nice ride you have there. Any pics?
