riden2low
Have a 95 ATX and I think the rear passenger side drain is plugged as I am getting water dripping on the rear back seat from the back of the headliner when it rains hard. It will even get into the trunk. I have blown out the the two front drains but how do you get to the rear ones. I was thinking of taking the head liner down in that area to see if there is a rubber tube that comes off of the drain or is a metal tube all the way down. If it is rubber, maybe can reattach it. Can you blow air or run a small wire into the opening from where it drains under the car?
