Moog CC to cut, or not to cut?
3taps
orange county,ca
94atx, with kyb gr2's would like to keep stock heigth, how much to cut or not cut at all? if cut will they seat flush, meaning the fronts? I bought the moog mounting kit. what kind of ride? please feel free to share any and all thoughts please, thanks in advance!
SHOtimer
#2910
Santa Clarita, Ca
The rears I would leave alone. I would cut one coil off the front springs. That would pretty much give you a stock ride height.
Doug
3taps
orange county,ca
which is the top
The front 858 does not really have a tightly wound side, one side is just narrower, the spring kind of looks like a christmas tree as an example. Top=narrower?
DHMag
Free At Last
InCahoots, Texas
the narrow end is the bottom.
the dead coils are on top on fronts, on bottom on rears.
CC858 front, 1 1/2 coil cut from top
CC839 rear, 1 coil cut from bottom. all coupled with Tokicos <---my car
3taps
orange county,ca
Thank you all, vehicle is at the shop getting the springs installed as I write this. Another question, if I change the subframe bushings in the near future will I have to have the vehicle realigned?
Stracey R
You only need to get it realigned if, you mess with the tie rods, control arms or even the struts/springs.
Do the sub frame bushings one/two at a time.
