Thank you
@Ta2dResqr. You were for the record correct. It wasn't anything that didn't get attached or a bad connection, but in fact something small. After rechecking all said connections well, and even trying the new control module, still no fuel. So we pulled the assembly again and rechecked everything there. All seems to be exactly as it should. I was puzzled. No codes the issue had to be in the tank right? So I begin to take apart the clips for the new fuel tank strainer/ filter that goes below the pump in the cup because discouraged we're thinking replace the pump we know is working. I notice there is a lose part in the assembly. Turns out the replacement fuel tank strainer/ filter that goes below the pump in the cup was slightly taller. Allowed the (pressure regulator?) Just below the upward hose to the top of the assembly to unseat with its o ring and be loose. Result, fuel pressure not building into the hose but just bubbling in the cup lol. So we returned the original filter(painful choice but only 22k miles of use after all and 5 day wait to get a new one from Ford via buying the whole assembly) reassembled and reinstalled. Boom working dw300c!
Moral of the story... even if a 2010-12 is drop in no physical mods needed upgrade to the dw300c, I would recommend having a new assembly on hand anyway for the proper strainer to be changed in tank. Sucks that's the only way to get one, but worth it to not have to potentially redo the work at a later time.
