ashedd
Guest
- Joined
- Jul 27, 2006
- Messages
- 84
- Reaction score
- 1
So I am in the process of replacing the CPS. Since the car is jacked up I decided to look into my oil leak problem. I thought the first thing I would do is try to snug dowm any loose oil pan bolts(always worked on my 302's). As I was looking around for bolts I noticed a bolt so loose I could remove it by hand. This loose bolt was going from the oil pan(?) into the transmission. I figured that there "should" be another bolt very similar on the other side. I also noticed at this time that the oil appered to leak from between the transmission and the engine/oil pan. there was/is a small gap between to two parts and I can move the thin metal gasket with my finger nail. The bolt towrds the front of the engine is gone compleatly and the rear one was loose as stated before.
My questions are:
1. Will any bolt I find at the hardware work(as long as I match it up ofcourse)?
2. does this new bolt need locktite?
3. how tight should the 2 bolts be? should the end result close the gap up tight?
4. Would oil even leak from this area or is the leak from somewhere else(the entire bottom of oil pan and MTX is covered with oil)?
5. do you think with these two parts bolted together properly that would fix or help my hard to shift issues?
Any ideas would be great.
Thanks
A
My questions are:
Thanks
A
