tommyturbo
Got a valve adjustment and cam chain tensioners replaced today, the job Matt W did was excellent...and I enjoyed helping some and learning a thing or two. I know this is not related to anything he did, but figure maybe someone might have had a similar experience after doing such a job.
Car runs good except for one odd thing. it's a 95 atx.
I didn't notice this until after being on the fwy a while coming home, haven't noticed this in the past.
There is a weird dead spot at 3200 rpm +/-
Noticed when under load at fwy speed, in 4th, if you start to accelerate the converter unlocks and the car pulls nicely until about 3200 rpm, then it looses power, but if you increase throttle, it downshifts to third and pulls nicely.
I repeated this several times to be sure.
On the way home went to some quiet empty areas and did some tests.
From a dead stop in drive, it breaks the front tires loose and pulls nicely, power seems soft (but not as notice of a drop off) as it gets close to 3200 then it pulls nicely after that.
If you lock the shifter in 1st, it breaks the tires loose and pulls, I can't say I noticed the power drop off, or it was much more subtle. it always seems to feel strongest after 3200 rpms.
Now on a moderate throttle accleration, it seems fine, but when it
shifts to third it puts it right at about 3200 and it really feels noticable the lack of power.
When I got home I ran codes. Key on engine off, 111 system pass, no mem codes. Key on engine running, I get 225, knock sensor not detected. All my fords always throw that code when I do the engine running test...so I don't take it too seriously.
Any suggestions? It felt almost like a misfire at one point, but if it is it's very minor missfire.
I checked all the wires seemed tight on the plugs and at the coil pack.
Any advice?
Any advice?
