Mirrors Not Working?
BasedBidoof
Brandon, Florida
Hey guys, I was wondering if I could get some help on this. So I finally got my sho running, but my drivers and passenger mirrors don't work. I have not done any checks on the switch, nor do I know if there's a fuse. So I was wondering if you guys could help me on this. Also my door locks don't work, but I know that's the switch but it could have something to do with it, so I figured I'd mention it.
Thanks!
Shovert
ky
Since no one has chimed in. I have never got into the SHO door wiring but I did have to redo my Mustang and my Jeep Cherokee. What I found the wiring was broken in the flex rubber boot between door and body. Unsure obvious if that is your problem but I can see where it is a common problem.
What I did was [one wire at a time] cut the wire near body connector and past bad places. Install same size wire. Solder it and heat shrink it. Maurice
NEp8ntballer
cyber ninja
fifth circle of ****
make sure all the fuses are seated properly. On the 91 I just bought the interior lights, mirrors, radio and key pad all run off the same fuse.
