Mild Knock
GoofSHO
HUGE Dreamer
Vegas
Here goes....Mild knock at idle-between gears. Under load (accel or decel ) no knock. Replaced rod brngs, no change,brngs looked good for 140000. Thinking piston slap?or.....Any ideas
Thanx
B :cool:
F-22 Raptor SHO
7015 feet above Sea Level
Piston slap....very unlikely. Is the noise sound like its in the upper or lower, left or right portion of the motor.
Cam chain tensioner could make a ticking at idle.
GoofSHO
HUGE Dreamer
Vegas
With a stethascope it sounds loudest from the front bank, middle cyl. Vadim said maybe cam tensioner. I read on a post that the T-belt tensioner made noise for someone. Injectors, no, different sound. Thank you for the input though...Really. I need as many ideas as possible...in case I'm overlooking something.
Thanx to all that answer
B
bgjohnson
iowa
mine is in the exact same position as you describe, i'd like to know to. i've already done the shimming to all my valves. so i have no clue. and isn't a tensioner more of a chattering not a ticking.
