Meth or Turbos
sho2010pp
I've got a 2010 SHO with LMS 3bar 4x tune, T-stat, and PPE catless DPs.. What would be the next step in this build?
OmaHahn
Omaha
No upgraded turbos? Meth is a better solution for power and cost wise? I also need just that one more step to achieve some more "POWAH!!" I want to be over 500 crank HP!
Meth is a sensible solution for that 500 CHP goal. In addition, it cleans up the backsides of the intake valves, which becomes more important as the miles accumulate. With a good system and a proper installation, you should only have to worry about keeping the reservoir full enough to accommodate your lead-footed ways :nut:
rmc5973
i have a / i have a 97 rx7 an i can drive it about 50 miles an it will shut off and i wont be able to start it for about an hour what could cause
