my car seems to have the poor IAB symptom of dropping to 1300-1400 rpm from load, and then creeping down to maybe 1200 in neutral and on to 8-900 only during a stop or long neutral coasts.
i cleaned my iab out today with some carb cleaner and reset idle but it doesent seem to have cured the issue.
the mechanism wasent really sticking, but was fairly gunked up. i dont know if i was supposed to try and pry the section sandwiched between the TB and IAB loose and de-gunk that or not.. i did spray liberally and wipe down the two ports exposed after removing the IAB.
and my ford dealer said they cant source a new one and to try a auto wrecker.. ?!
heh any ideas about a solution to the idle issue or fining the part (already emailed fpn btw)
