SHOkid13
Take it to the track
Okay, I haven't been able to figure it out... After putting in my Quaife and a full tranny rebuild, I got a massive shake when I am in reverse, especially at lower RPMs. All of my mounts looked good when I had it all apart, and they are all connected and tight now.
To explain the shake: Feels like the engine wants to drop out of the car!
Could it be the combination of clutch, Quaife, flywheel, etc?
It didn't do it when I had the new clutch only.
Thanks...
Thanks...
The bearings were pressed on all the way with a multi-ton press: they are tight. I meant I put the case halfs together before final assembly and turned the input shaft with none of the other gear clusters installed (same kind of thing for testing the quaife fit). I was able to turn it by hand, but it had plenty of pre-load.
Really? Not to sound stoopid but I've never done that before when balancing any of the ford or toyota motors I have built... Never had any issues with them... We would always send down the crank, flywheel, harmonic balancer, pistons, rods, etc. and never sent the pressure plate...
