Mass Breakfast meet July?
RStalveyARFF
too many shos
Georgetown, MA
Skip, got any pointers on removing the blower tubing? Spanner wrenches are hard to find... Also I'm definitely going to need a carpet, this one is yesterday's news.
Leforrest
Coventry, RI , usa
If you need to remove the IC tubes, I normally pull the SC top with the top IC tube on it. 4 bolts at the SC and 2 nuts at the IC itself. I really don't screw with the spanner wrench. The bottom one is a little trickier as it's also bolted to the Power steering bracket.
As far as carpet goes,,,,mine isn't mint. it could use a cleaning and that's probably all. Doesn't a company like JC Whitney have carpets cheap? It might not even be worth going with something used if you can get it cheap enough new.
What do you have left to do to the car?
RStalveyARFF
too many shos
Georgetown, MA
Hehe, I've got everything left. I just towed it up to my shop last night so I've yet to tear into it, save for replacing the ignition lock since I left the keys on the bed when I originally towed it. :( I've got to replace the head gaskets, so I got the upper gasket set, along with a water pump, plugs and wires, and a radiator. I need to get a new accessory belt too. They put a 6 rib on instead of a 7 or something like that.
Leforrest
Coventry, RI , usa
Hmmm, luckkkky you!
I have done the HG's before. Not a lot of fun. Let me know if I can help.....Other than doing the HG job for you!!! LOL!
