Map Sensor
ridered74
2.5 is cheaper. Depends how much boost you are running. Personally I'd rather not be on the edge of what the sensor can read, but if you are only running 16-18 psi and not going to push it any further, the cheaper one would be fine.
Give yourself more options with the 3.0 unless you are certain of the parameters you will be running and not want to change
