Many Codes pulled need help diagnosing...
aaronsbiza
Sacramento, California
95 ATX 96K,
I was driving my car the other day when presented with that nasty check engine light. I ran my codes to day and was given a whole slew of them. I was able to reference a few of them but could not find anyhing on the remaining.
511, 117, 245, 254, 217.
Thanks in advance.
rangerj
Brunswick, Ohio
511 EEC (PCM for 93 and later) Processor Read Only Memory test failure
117 ECT (Engine Coolant Temp) sensor circuit below minimum voltage /254F indicated. Was the car overheated or ran in the very hot range. If not the sensor either has a bad connection or is failing.
245 ?
254 ?
217 EEC (PCM) Processor detected Coil 3 primary circuit failure
Check your DIS connections.
aaronsbiza
511 because I have a Ted B. Installed.
The ECT Is original and probably failing.
245 I can't find anyhting?
254 I Can't Find anything?
217 I will check my DIS Connection
