the-SHOning
I have a 2011 SHO, I will barely press on the gas and the boost is adequate, but not great, if I put my foot down, it bogs down and I have major boost lag or no boost at all, also times when it seems like if I ever gun it, there's no boost just engine rev...this is causing a higher Rpm range than what it used to be and my gas mileage is suffering. My friend and I believe it's a possible pre-ignition issue but not sure, never had an engine light come on, Ford wants 100 just to diagnose the issue... I'm in need of an oil change in the next week or so anyways, so hopefully I can pay for the diagnosis and get half off an oil change. I know I have a slight oil leak from the rear turbo feed line, but I'm not sure that would cause such an issue, read earlier of a MAF / CAC cleaning that someone did with similar issues. Anyone have any ideas??
