redwraith94
I am almost done rebuilding my mtx trans, and I am at the point where I need to reshim all of the shafts in the transmission. The factory service manual says to replace them with 'maintenance shims' if the bearings have to be replaced.
So i need to either get ahold of a set of maintenance shims, or I was thinking of going with the peelable shims from shonut, as they should allow for the maximum efficiency.
Do you guys know what the fitting procedure is for the peelable shims? I read through the service manual, and found the procedure for the 'normal' shims, is it the same, or completely different?
Mike
Mike
