OK I contemplated lowering the SHO quite a bit before deciding on going with Eibach but I must admit I was a little disappointed on the amount it actually lowered the car. I measured right up the center of the wheel to the fender well. My car started at F-29 3/4 and R-30 1/2, after the Eibach's were installed and a few weeks later the cars at F-29 1/2 and R-29 3/4. So I'm looking at 1/4" to 1/2" on the front and 1/2" to 3/4 on the rear. The number seem to move around from time to time. The front even went up when I filled the tank, I think because the rear went down slightly.
So here my next step...I'm going to switch out the Eibach's with H&R's!
I'm looking for a more sporty look.
One thing that has been noted in the past is the H&R's may need the camber bolts replace with some after market ones. My question is where do you get these bolts and how much are they?
If anyone with stock 20's and H&R spring would like to take the same measurement I noted before to give me a real idea of what I'm going to get for my trouble I would appreciate it.
Thanks!
Thanks!
