Lowering Springs Shock Replacement
Jeff Clawson
Hi, new to the forum so forgive me if this has been addressed. I recently installed the H&R lowering springs on my 2014 SHO, and the stance is much improved. However, the ride is now somewhat "jiggly". I have been looking for replacement shocks that will work with the shortened suspension, but nobody seems to have shocks for my car. Can anyone recommend a good shock that will calm down my ride, and if so, can you supply a part number or reference?
gary4n
Fl
Take a look at Koni and Tokico. They are a good choice for your lowering springs.
Sadly, there aren't any real alternatives to OEM for the 2013+ SHO. 2010-12 MYs have Megan coilovers available, which are a substantial upgrade over the H&Rs.
Was an alignment done after the H&Rs were installed? Were the shocks checked carefully for fluid leakage (indicating shock failure)?
Jeff Clawson
Alignment was done and they were able to get it in factory specs (barely in the case of the rear)... I don't think wear is an issue as the car has barely 20k miles and has been babied. I'm a little surprised there would be a difference between the 2012 car and the 2014, can you tell me the difference as relates to the shock fitment? It would be nice if I could get the Megans to fit...
It's easier to mount the shocks & struts on the 2013+ than the 2010-12 (no knuckle removal required), but the mounting systems are different enough between the gens that Megan themselves has not created the 2013+ kit. If you are a fabricator you could possibly convert a 2010-12 kit, but truly would be a one-off. There's no knowledge in the public domain about such a conversion.
This thread will give you some background:
http://www.ecoboostperformanceforum.com/index.php/topic,1901.0.html
