Arjun
The car: 1989 SHO with heads rebuilt 8000km ago.
For the past couple of months, at idle there's been an occasional misfire-- nothing significant enough to make me want to pull the codes.
Today I'd driven to school, parked for a couple hours, then I headed home. I left the parking lot, and my car felt the way it normally does. A minute or so later, I pull up to a left-turn light behind a Mazda 323. As soon as we turned onto the highway, I was going to whip past it.
...Except that I noticed that the car was sounding funny and my idle speed had just dropped a couple hundred RPM. Damn SHO, giving me problems again. ...So the light goes green, I start driving, and there's low power-- feels slower than my mom's car! I pull off the road, check in the engine bay, everything looks normal, exhaust smells a little gassy. Remembering a couple years ago when my spark plug wells were filled with oil, I pull the plug wires individually, and they're clean. So I fired the car up, and cruised home slowly.
Get home, pull the codes. KOEO tells me I've got a stored code 46 (coil 2 primary circuit failure). KOER gives code 11 (no problems found). Cylinder balance test shows problems with cylinders 3 and 4.
From here, I'm not sure where to go. I just called up the parts place that I deal with most often, and a coil pack costs CAD$153, DIS module CAD$165.
I'm not sure which of those two are the most likely culprits-- any suggestions? Anybody have any idea how to test one or the other?
Thanks for any help you could provide!
