munkee
Too busy...
I recently bought a 91 plus in need of some work. I has 105k on it and was knocking pretty bad so I started with the rod bearings. There were a few starting to show some wear but weren't too bad off except for the #6 bearing, which was badly worn and had a small chunk missing on the bottom bearing. I have a pic of the bearing but I can't figure out how to post them. Aside from a couple of light scratches the crank looked alright. A few hundred miles later the low oil light flickers on when you come up to a stop sign, usually as the tach hits about 6-7 hundred rpms. Then yesterday the light would start flickering at 1000 rpms and stay on at idle. Where do I start looking for problems? Supposedly the previous owner never changed the oil in the 29,000 miles he owned it, and judging by the sludge in the pan I wouldn't doubt it. Could this have hurt any other bearings causing low oil pressure? TIA, Chris.
