CheckerSHO
Ford Employee
This 93 atx has been a big problem so far in the few months i've owned it. At this point, the main problem i am having is oil pressure. When i first got the car, the oil light would flicker at times at a stop when hot. So i do the usual thing and replace the rod bearings. There was no engine noise at that time besides timing chain tensioners(repaired that too-was streched chains, also cleaned tensioners out while they were out). I didn't look at the main bearings...i probably should have though. because the light still comes on at idle when hot. So i put a manual gauge on it and its dropping below the spec( 12.5psi hot idle). Has anyone on here run into bad oil pumps on these motors? Just trying to gauge which would be more likely before I tear back into this thing. If i have to do the oil pump it will be the 4th time that timing belt has come off in 2 months heh.
