Low oil level sensor/sender leak
jthod
Mr. Goodwrench
Lincoln, Nebraska
This thing has ben leaking since I got the car. Now it's the last seal other than the oil cooler seal that I havn't replaced. I've pulled it apart a couple different time and RTV'd it, but it just keeps on a leaking.
I know you can get a replacement sensor from F***, but what does that consist of? Is it the wire also? What have you guys done to stop the leak?
I thought about getting a plug that would thread into the pan. Toughts??
Storm-Chaser
Shit Louis
There is a separate sensor and gasket, both of which [were] still available from F*** the last time I checked. Try replacing the gasket first.
jthod
Mr. Goodwrench
Lincoln, Nebraska
Is the gasket the blue tube type piece that goes between the sensor and the housing?
The oil is coming out of where the wire goes into the sensor.
Storm-Chaser
Shit Louis
You need to change the sensor. That wire you see, is actually the male-terminal for the sensor, that the female-terminal/connector connects to.
SHOtimer
#2910
Santa Clarita, Ca
The gasket is a rubber and metal washer that fits and seals around the sensor. It was only a couple dollars last time I replaced it. It is easy to pull, a new gasket requires no RTV and doesn't leak!
Doug
jthod
Mr. Goodwrench
Lincoln, Nebraska
Any one have part numbers for these? yes, I'm lazy, and the Ford parts guy is below par, more so than most.
