Low Coolant Light
theaterkeith
Florida
Is there any simple fix for this, besides pulling the bulb, coolant tank has plenty of coolant, sometimes it comes on sometimes it doesnt. Cleaned the connector and the sensor portion as well.
theaterkeith
Florida
No or at least it hasnt anounced it to me yet, cooling system work flawlessly
so i am assuming it is still pumping
LeddZepp8687
The Keg Rider
Naperville, IL
Mine comes on somtimes, and sometimes doesnt come on.....Yet I dont think im leaking coolant..
What does that mean?
naval-avi8or
Chesapeake, VA
HootUSMC said:
ummm world famous ford electrical bugs
You just need to pull the sensor out and clean it. It works by two metal probes conducting electricly thru the coolant. when the probes corrode than it doesn't matter how much coolant you have it thinks its empty.
SHOslyter485
Fort Collins, CO
The first guy said he cleaned the electrodes already..
Are you 100% sure you aren't leaking coolant anywhere? If you've thoroughly cleaned the sensor, its a possibility that your sensor could be going bad
T.O_SHO
Power Hungry
Toronto, Ontario
As much as I cleaned my last sensor, the light would not go off, post a wanted to buy for a new sensor, and you should be good to go, granted the problem isnt bigger, like a leak or something.
nkb93
SLO 4 SHO
Charlottesville, VA
If you unplug the sensor, the light will not illuminate. At least it doesn't on my car.. Mine's been unplugged for 5 years ever since the sensor shorted out and melted down.
95azSHO
phx,az
Hey guys thanx for the info mines doing the same for 2 weeks now. Its been drivin me crazy cause I just can't find anything that could be causing it.
Wht91+
93 Green MTX
Oconomowoc,WI
Agreed:thumb:
theaterkeith
Florida
yes was cleaned with a contact cleaner then an emory cloth and when those didnt work rehit it with small wire wheel. Till she dazzaled like a diamond. im not worried about it coming on and off, wife drives it once in a while and gives me shit everytime. Thanks for the info will try to get replacement.
