loud knock from head
wicked740
ohio
I am havein a knock come from the front head.but it only does it when car is on not at all while car is cranking. Anybody know what it would be?
shoreracer92
Davenport, FL
i've had a knock since i bought the car (10k ago) and it comes from the front head area. doesn't quite sound like that though. it doesn't happen when i do the KOER test, so i figured its a injector rap... just sayin. and theres a few posts about knocks on here... search alil bit.
wicked740
ohio
Also I have the front three plugs out and I can only turn motor half way then locks up so I bubump the starter and can do another half turn before it locks up agine
Irish Pride
Irish Inside
MusicCityUSA
Is it an ATX? Could be a failed timing tensioner. I just went thru that last month.
wicked740
ohio
No its mtx! I took off intake and found a small hose clamp in the front midal intake valves.i found both peices but did not find the screw for it but all valves seem to be good. U guys think I will have to pull the head or is the block going to be messed up
jayro
Auburn, In
You could pull front exhaust manafold to see if it gives you better access to different areas in the head. Though pulling the front head is fairly easy.
Have you tried fishing with a magnet yet?
wicked740
ohio
I have allready pulled front maifold and did the magnet down in the sparkplug well on top of piston and on intake and exsuaut valves. Is there an easy way to check the rod b cause im dissabled and have 8 screws in my back so,any help will be awsome.
jayro
Auburn, In
Not Easy, but not hard. You can get to them by pulling the oilpan. Then you unbolt the girdle and oil pickup tube. At that point you are staring at the crank and rod caps. Undo the caps and check the bearings.
Of course you have to remove the y-pipe to get to the oil pan, but if you have the manafold off then the y is already off.
wicked740
ohio
Would there be signs of rod b like metal shavings in oil pan? And also if it was rod bearing wouldent it make sound even when cranking not just car on. How do you put videos on here I will try to make a video for you guys.so you can hear it
auto.guru
Village Idiot
Neenah WI
as being a leader of throwing rod bearings.... yes, you will have a crap ton of copper and aluminum looking shavings in your oil. just drain your oil first - and use a coffee strainer. If you have a bunch of particles then there is no point to pull the pan. its obvious you threw a rod.
otherwise.... start the car and start pulling spark wires as the car is running. if the noise goes away thats your trouble cylinder and more than likey its a rod bearing. if it doesnt go away - that screw is probably bashed into the piston top and its smacking the cylinder head
wicked740
ohio
Ok thanks ill try that tomarrow. But I got to thinking about it I need to,start it and make sure its coming from the front front head cause my two other shos ive had both had the diff failure and the knocking sounds like that
auto.guru
Village Idiot
Neenah WI
Well pulling your wires will determin the source. If all wires pulled and it doesn't go away, its not in your rotating assembly.
And the diff doesn't turn unless your in gear I believe.
wicked740
ohio
Well I pulled off the wires with car on and nothing changed so I pulled the head off and the screw was stuck to the head between the valves they seem to be fine is the indent on the piston going to hurt anything there isent any damage done to cylinder just small spot on top of piston and the spot on the head
sperold
Last to Know
Put it back together. If nothing is smashed with cracks radiating from it, it will be OK.
wicked740
ohio
Cool thanks alot guys waitin for headgasket and then its going back together no cracks just a indents
