No its mtx! I took off intake and found a small hose clamp in the front midal intake valves.i found both peices but did not find the screw for it but all valves seem to be good. U guys think I will have to pull the head or is the block going to be messed up
Would there be signs of rod b like metal shavings in oil pan? And also if it was rod bearing wouldent it make sound even when cranking not just car on. How do you put videos on here I will try to make a video for you guys.so you can hear it
