I have a 1995 SHO that is losing coolant. From where I do not know. There are no drips or puddles on the ground. There are no visible wet or damp spots on the enging or the engine compartment. Over the last month or so I have driven approximately 100 miles and have had to add 1 gallon of coolant. This was spaced over 7 or 8 incidents of adding coolant but the total was 1 gallon added as I just finished off the gallon last night. I am using a 50/50 mixture. Although there are no leaks visible anywhere after driving 5 -10 miles at speeds 35 to 70 when you stop and get out of the car you can 'smell coolant around the front of the car'. The temp gage(factory) usually rides around the M in NORMAL. However, lately (since I have started losing coolant) the gage will soar above the N but not above the line just short of HOT. If you de-cellerate, not using the brakes but just let the engine wind down, the temp goes up a little. If you engage the clutch and rev the engine the temp goes down some and if you accellerate the temp seems to go down some or at least stabilizes. The fluxuation (up and down) on the temp gage from around the M in NORMAL to the line just above the N (almost to HOT) is fairly rapid after driving 5 - 10 miles. This fluxuation doesn't start until once the gage has gotten to it's highest temp reading then the varing readings start. I know factory gages are notoriously inaccurate and I am not worried so much about the gage movement as I am about the loss of coolant...that's not a factory defect or gage shortcoming. I believe what my gage is telling me is pretty accurate because it was accurate last year when I was having cooling problem and we had it hooked up to a computer checking the temperature that the thermostat was opening and closing, also when the fan was coming on and going off. Any suggestions appreciated.
Thanks,
adavery
Thanks,
adavery
