Loose steering
MD Ever
MeanestDad Ever
South Lyon, MI
First make sure everything in the front end is tight (inner/outer tie rods, balljoints, subframe bushings, strut rod bushings, wheel bearings) then replace the steering gear. You could try to tightend up the gear but it is a long drawn out procedure and usually ends up with a binding concern.
mclarida
Orlando, Fl.
Would the vss have anything to do with it? I think mine is bad and know I have the speed steering thing. Just wondering-
M
MD Ever
MeanestDad Ever
South Lyon, MI
No, VAPS won't give you any play...just make it real easy to turn at higher speeds (full assist at all times). If you notice the play while sitting still or a low speed then something is worn.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
crawl under the dash and look at the slider assembly while turning the steering wheel. check the clamping bolt while you're there.
92silverbullet
wi
clunking noisees
i know i need a new inner tie rod because i can move the wheel backand forth but what is the clunking?? i replaced my subframe mounts so i was thinking its must be the strut mounts..
