Loose steering
stevemainian
Virginia Beach, VA
When I hit a *** hole or bump(speed bump), the steering wheel becomes loose, and shakes back and forth. I replaced the drivers side tie rod end, because it went bad, do you think if I replace the right one, this "loose" feeling during *** holes and bumps will vanish?
projectSHO89
SHOless In St L
You will need to locate the loose/failing part before replacing anything.
Guessing won't cut it.
Steve
stevetatro
Cincinnati, Ohio
Steve,
Do you know of a consolidated explanation detailing how to diagnose such problems? I seem to hear a lot about people who know they have a steering/suspension problem but have no idea how to find out what's wrong. I guess a lot of the parts boil down to the bushings being intact, but what about inner and outer tie rod ends, wheel bearings, ball joints, strut mounts, etc.
Thanks.
sho_bc
Dragonboater
Vancouver, Canada
the on going reality of shopower said:
i have replaced almost everything and still has a few clunks. next thing is strut rod bushings
thats the way to do it! :D replace everything, and that way you're sure to get whatever it was that was wrong, as well has having a nice brand new suspension as well. :thumb:
