Looking for performance parts.
Tactical SHO
Bit Late the the SHO
Lodi ohio
Well that's probably everything but I'm open anything that would be a wise performance mod let me know just trying to save some money before I give it all to Sho source.
B.B.B
Cat back
Cold air intake
Perfomance Mass air flow
programer
Injectors to match these mods
Sway bars
Bigger brake kit
Performance cams.
Tri Flow or might be open to others. wish list.
Or S/C set up. Wish list.
SV&HOdan
Pittsburgh PA USA
hi,
I'm assuming you found a gen2. I'd have 24/26 mm sway bars and I have a big brake kit that was on a 93 front suspensio.
if interested, pick up only in Pittsburgh.
thanks,
dan
Dan, do you also have a gen III SLO subframe and knuckels/ hub/control arms? Be nice to eliminate the strut rods on his 95 :nut:
Tactical SHO
Lodi ohio
Does the gen 3 sub frame bolt up to the 95 or does it require major modification. I did order the SHO Source coil overs and would need that to work. Thanks
When I had the subframe mod done, there was a relatively minor modification that was needed. There are threads on this forum that will show exactly what's what. I had a local SHO guy do the whole thing, so he wirewheeled and painted the subframe prior to installation, looked great!
http://www.shoforum.com/index.php?threads/gen-3-subframe-mod.122743/
Good time to put in Gen 3 bushings also. But that thread is a big help.
SHOsource can better answer your questions with regard to compatibility of the coilover kit & subframe mod, but considering that I did not have to change shocks/springs after, I don't see any reason why it would interfere with the coilovers either.
Tactical SHO
Lodi ohio
I just ordered the SHO Source catted Y pipe. And i ordered the SHO Source coil over kit. Other than that I'm all stock with flowmaster weld on mufflers for sound and custom fitted tips. I Would love the SHO Source cat back with
Tactical SHO
Lodi ohio
crystizel
