roswell998
I've read quite a few threads re the correct fuel pump and it appears that most recommend the 115 lpm pump. However, as time go by products and recommendation may become dated.
However, several topics have been beat around and raise the following questions (for a stock 93 3.2l atx with no performance mods):
1. A different pressure regulator is recommended for 150 lpm and larger pumps. What happens if you don't change the regulator?
2. Since the 115 lpm is higher capacity than stock, is a different pressure regulator recommended? If not, does the larger pump shorten the regulator life or realiability?
3. What is the advantage of a 115 lpm vs a standard (85 lpm IIRC) pump used in a stock application?
4. Any other advantages or disadvantages of using the 115 lpm pump?
Thanks
Thanks
