Well, then let me rephrase - on all 3 of my atx cars, one fan will run w/ the a/c and the other will come on w/ high coolant temp.
Who said not to change the ECT sensor?
Trust me, that's the part you want to replace. The fact that your fans come on with the auto climate control shows that the PCM, CCRM, and fans themselves are working, the ECT sensor is the last component.
it's an Automatic so an ATX i guess.. And it's not the fan motor because it turn's on when the AC is turned on and also the wire's are fine.. And i understand that the PCM turn's the fan's on but a sensor must tell the PCM when it's time right? Well i need to change that sensor so what im asking is which Sensor that would be... Would it be the one in the picture o posted? im starting to get confused.. Thank you
Sure, the new member and first time poster didn't provide a detailed resume and specific description of his car, but he's new so we'll cut him some slack and actually try to help him solve his problem instead of incessantly complicating and confusing the issue. Now, since he is posting in the V6 section, it's probably a good bet that he owns a V6 car. He's describing a cooling system problem, and while there are slight differences between the ATX and MTX cars, as well as some differences between years, the core system is essentially the same regardless so we'll just read his entire post and take the totality of the information he's provided and see if we can help or if that additional information is critical to helping him solve his problem.Hi im new to the board's and a new SHO owner.. i love the car but recently it started to overheat during Idle and the fan's don't come on but they do with the AC on so my uncle told me its the "Cooling fan switch" but i don't know where it's located and that engine compartment is pretty packed.. Anyone have any idea? It would help VERYYY much.. Thank you -Matt
The reason I ask, is that the ATX uses two cooling fans, triggered by two separate relays in the CCRM. Thus [you] need to verify that both fans operate correctly, not just that "a fan comes on when . . . . ".
When the A/C is engaged both fans are actuated continuously and do not cycle on/off with the A/C clutch. Thus it is one of two ways to determine if the both fans operate. The second is to simply provide a 12-volt power source to each fan and see if both actuate and run.
Of the two fan relays, the Low-speed Fan Control relay is activated by the CCRM when the PCM determines that the engine temperature is higher than "normal". The PCM signals the CCRM to energize the relays. The Low-speed Fan Control relay activates the fans at low-speed when engine temperature reaches 215° F (102° C) and deactivates the fans when engine temperature drops to 210° F (99° C) (if the A/C is not on).
Ok, let's try to simplify this for normal people with common sense in an absurdly complicated way...
Let's start by looking at the OP's initial post:
First, he states that the car has started to overheat at idle. Now, seeing that he is from Tucson, he's probably still seeing outdoor temperatures in the 50 to 70 degree range so overheating at idle can occur rather quickly. Starting a cold car in 60 degree weather should result in the fans coming on in about 10-12 minutes or so of idling -- you don't need any fancy diagnostic tools to determine this, it's just something that anyone familiar with these cars knows from experience. Further, being from that part of the country, he is probably familiar with the symptoms of an overheating engine. Sure, he doesn't describe the extensive diagnostic procedures he followed to come to this conclusion, but often a temperature gauge above the normal range and coolant boiling over are all you need to know (I know, I know, but the service manual didn't say so!).
Second, now let's see, he refers to the "fan's" (forgiving his innocent punctuation error) in the plural, so it's reasonable to deduce that he's driving a car equipped with an automatic transaxle since only those such cars were equipped with a dual-fan setup. Again, this isn't necessarily critical information, as the totality of his symptoms and description render the point more or less moot.
Third, his uncle, who has probably never worked on a SHO in his life but obviously has a keener sense of common sense than someone with their head buried in a service manual, came pretty close in his suggestion that a failed "cooling fan switch" was to blame. While he may not be up on his ASE vernacular, he obviously has actually been under the hood of a car and not just spent his life memorizing a service manual.
Fourth, he stated that the fans "do [come on] with the AC". Again, for anyone with an ounce of real world familiarity with these cars, this is a clear sign that the PCM is functioning properly as it is able to command the fans on; that the power relay in the CCRM is functioning since it is able to power the fans; and the fact that the fans are turning indicates that the fan motors themselves are functioning properly. Common sense dictates that the ECT sensor has likely failed, since this behavior began "recently" and thus unexpectedly, and the gauge sender indicates an unusually high temperature. While certainly not impossible, the likelihood of simultaneous ECT sensor and gauge sender failure is unlikely, so in this set of circumstances it is again reasonable to conclude that the gauge showing temperatures above normal is likely accurate.
Unfortunately, instead of just letting the OP solve his problem quickly by helping him identify the correct ECT sensor, it's location, and eventually how to change it, someone had to pipe up with completely superfluous nonsense about CCRM letter codes to completely muddy the waters -- as is his penchant to do, and then of course exacerbate things further with more useless trivia that has zero bearing on the current state of the OP's issue.
Let's illustrate absurdity by being absurd just a bit further...
Let's suppose instead that the OP posted asking what to do about a flat tire.
Most people would advise him to change over to the spare and see about having the flat repaired.
But, there will always be that one person who needs to correct and admonish everyone else, and go on to explain the chemical composition of rubber, how the tire was manufactured, what the correct tire pressure is, and lengthy procedures requiring lots of fancy equipment to determine why the tire failed. The big ass nail sticking out of the tread is not nearly a simple enough common sense conclusion... That about sums it up... :shakehead
Just to clear this up there are two fan relays. One high speed which allows full voltage to both fans and on low speed relay which runs the voltage through a dropping resistor (in the case of the ATX) and the provides a lower voltage to both fans. . . .
If the PCM determines that the engine temperature is higher than "desired", the High-speed Fan Control relay activates the fans at high-speed when engine temperature reaches 230° F (110° C) and deactivates the high-speed (fans step-down to low-speed) when engine temperature drops to 224° F (107° C).
Here is a thermal time-line on when the fans should operate as a function of engine coolant temperature:
Off < 210° F (99° C) | Low-speed | 215° F (102° C) > On | Off < 224° F (107° C) | High-speed | 230° F (110° C) > On.
Ok so i changed my ECT Sensor last night and after word's i let my engine hear up and it went to about the "N" and then the fan's turned on then today i drove and it went almost past the n with no sign's of slowing down but i had already arrived where i was heading to see what would happen.. Shouldn't the fan's have came on by then? One more thing just a little while ago im driving in my car for about 5 minute's and i had the heater on and all the sudden the guage starts going up to the N and it's about to pass it and the it drops really quick to about the M or A what could that have been? thermostat? or what? i also needed to add a bit more water because i let some drain out before i changed the ECT could that little bit of water make that happen?
p.s. What's "PSP switch/circuit open" ? that code came up and i have no idea what it is.. Thank's
Large fluctuations on the temperature gauge are often blamed on thermostat, but that is sometimes not the problem at all. Thermostats are pretty dependable. Go down to Autozone or Advance Auto and get their loaner radiator pressure tester. Last time I did it was a $75 deposit, 100% refundable upon return. Pressure test the system. The SHO cooling system is sensitive to even small pressure leaks. It should hold rated pressure for 2 minutes. If it does not, use your eyes and ears to look for bubbling or telltale drips that are leaks. It may be as simple as a loose hose clamp, or as complex as a bad WP seal. Once the system holds pressure, hook the tester to the radiator cap and see if it holds pressure up to its rating. Unless it does so perfectly, go to the parts store and get a new Motorcraft, and only a Motorcraft, cap. Caps fail far more often than thermostats. Also check the lower radiator hose to make sure it has not become so soft that it is collapsing. New OEM lower hoses are hard to find.Ok so i changed my ECT Sensor last night and after word's i let my engine hear up and it went to about the "N" and then the fan's turned on then today i drove and it went almost past the n with no sign's of slowing down but i had already arrived where i was heading to see what would happen.. ... what could that have been? thermostat? or what?
