location of engine computer
klemklubfoot
quesnel
where would a guy look for the computer in a 91 sho, i just got a x2j and want to swap out my original
thanks
jmpSHO
Massachusetts
Pull the glove box down and look up. I believe there is a bolt under the hood to remove the connector.
klemklubfoot
quesnel
thanks for the reply, wow i went and checked it out looks like a job for the morning
tyrone
firebat45
Edmonton
There's a little white plastic bracket with 1 bolt holding it in from inside the glovebox, I think it's a T15. After that you have to undo the screw together connector, it's a 10mm bolt and you get to it from the engine bay, it's in the middle of the massive connector. Once the connector is loose you pull the EEC out through the glovebox. Don't be afraid to yank on it, the rubber gasket around it makes it tricky to get out sometimes.
