SHOOFF508
Out of Retirement (again)
The previous owner of my car pulled the bulb from the cluster. Ive been slacking on reinstalling it, and i figured id let the car clear out before checking it. I did the timing belt 2 weekends or so ago and had the battery out. so today i finally got the mil back in, stole the seatbelt light who needs it haha and i pulled the following :: (definitions are from shotimes)
111 (system pass)
172 Lean
176 Lean again
219 Spout default to 10degrees before top dead center(guessing this is because i pulled out the timing advance pill to pass a tailpipe test,it worked. not going to reveal who taught me that trick. (i live in MA it sucks)
542 Fuel Pump seconday circuit fail
any advice ? directions, keeping in mind the car runs fine, other than the occaisional long crank after a short trip not warming up and an occaisional stutter under 4k when cold.
thanks
111 (system pass)
172 Lean
176 Lean again
thanks
is that hole before or after the maf?
