can you PM me the bulb size to.. i unscrewed them outa the climate control but do they come outa the plastic piece or is it one solid piece??JoesSHO said:Check your PM
rigol2000 said:Oh and one day the wiper/blinker arm that turns on the wiper everytime I use my turn signal.
NJSHO said:The easy way is to remove the cluster to change the light bulbs in it. Im not sure about the bulb length. I did use the same bulb in the antenna up switch as the clock even though the base on the lamp in the clock was much taller than the antenna up switch.
Wow mine is the exact opposite. When my wipers are on and I use the right hand blinker the wipers turn off until the blinker is canceled.
