Litte help please.
sd8683
Boston
I just puchased a pretty much mint 1995 SHO off of eBay. The only problem is that it doesn't run. The previous owner said it would sometimes stall and the eventually it didn't run at all. From searching this forum it sounds like a crank position sensor. Would you guys and gals agree? Would there be anything that could be the problem? Any help would be greatly appreciated!
Here is the eBay item number 260505386728
Thanks, Sean
93rev2sev
Hockeytown
Congratulations on your new hobby. You've come to the right place. I see you have a few posts, and you done your homework. It sounds like you have a pretty good chance at a front 60k in your immediate future.
Here's a suggested parts list and a few things I've learned from lots of front 60ks:
Cam seals: yes, you should do them. Timken 1213n seals are like 5 bucks a piece and work great with a thin layer of anaerobic gasket maker. I don't recommend fel-pro seals. OEM ford (motorcraft) seals work really well too.
Timing Belt: I've never payed attention to brand, they've all worked well.
Water pump: Rebuilt, $50 specials work great, but be prepared to do the rest of the water pump-related gaskets and seals, too. Get a water pump gasket set, they don't all come with a water pump.
Crank Sensor: obviously. I've only used the Wells SU242, only because they are available locally and only about $50. Any brand should work great.
Front Main Seal: no brand preference. If they were all in a bucket, I'd probably grab the Motorcraft.
If all you want to do is hack a new sensor in so you can drive it, you can (I've never done this...nooooo) remove the connectors off of the new (or known good used) one and cut the sensor off the old one, tape them together and fish the new one through. Replace the connectors and voila, a 90 minute crank sensor repair. This works great in the auction parking lot! :biggrin:
jmpSHO
Massachusetts
Thanks, Sean
What did you pay for it, I bid on it last time it was on ebay for 300 but I missed out because I forgot I bid on it.
sd8683
Boston
I waited til about 5 minutes were left in the auction and I made an offer of $275 and it was accepted.
Thanks a lot guys! All this info will help immensely!
