Light bulb size
FOSHOMATT
Homer Glen, IL
can someone tell me what correct bulb size for the license plate and the interior light. I wanna get led's thanks everyone
You can look up the bulbs for your SHO here:
http://www.sylvania.com/en-us/applications/automotive-lighting-systems/Pages/lrgmain.aspx
http://www.sylvania.com/en-us/appli...bs.aspx?year=2010&qual=655&model=1973&make=30
There are kits available for the 2010-12, if you want to go the "easy" route. If you want to pick 'em individually, keep in mind there have been many instances of running changes in production, so it is best to pull & verify that you indeed have the same type bulbs in your SHO.
wuzzzer
MN Moderator
St Cloud, Minnesota
License plate lights are called festoon bulbs. These look like the LEDs I have:
 57
I had to bend the tabs in the bulb housings very slightly to get the to fit.
