Dirk37
Mr. Resourceful
There are a few different cams available for the V6's but no one place with information on all of them. The most common ones are:
3.0 Stock Cams
3.2 Stock Cams
Sho Shop Stage 1
Sho Shop Stage 2
SHOnut +10
SHOnut +20
SHOnut +40
SHOnut Tri-Flow
If you have one of these in your car, if you could reply with the following info I'll compile it into a master list for future reference:
-Low end performance
-High end performance
-Upper RPM where power drops off
-Driveability changes (ex. easier/harder to start off)
-Fuel economy changes
-Description of torque curve (ex. No effect until runner open,then pulls super hard until redline)
-Dyno curve and or HP/Torque if available
-Other mods on your car
If there are other cams or other info that would be useful let me know and I'll add them to the list!
Here's the preliminary compilation:
Characteristic |3.0 Stock Cams | 3.2 Stock Cams |
Low End | N/A | N/A
High End | N/A | N/A
Upper RPM | 6200 RPM | 5200 RPM
Driveability | Less mid tq than 3.2 | More mid tq than 3.0
Fuel Economy | Worse than 3.2 | Better than 3.0
Torque Curve | Lots of high end | Lots of mid tq
Hp/Torque | 220 hp / 200 ft/lb | 220 hp / 215 ft / lb
3.0 Stock Cams
3.2 Stock Cams
Sho Shop Stage 1
Sho Shop Stage 2
SHOnut +10
SHOnut +20
SHOnut +40
SHOnut Tri-Flow
Low End | N/A | N/A
